Author Topic: Skin Pack Requests - Post them here  (Read 167882 times)
Re: Skin Pack Requests - Post them here
« Reply #30 on: January 22, 2013, 04:57:24 PM »
Apologies if this issue has already been covered but...
The images displayed on the homescreen using a custom skin are displaying at an incorrect resolution.
Once I enter a sub menu they fine.
Mede8er 1000X3D, 50" Sammy Plasma, Marantz 1402 Amp
EDIT: My bad, the skins I'm downloading are compatible with X2, not X3... :-[
Please advise
Download X3 versions - you can find them here....
http://www.mede8erforum.com/index.php/board,135.0.html
Offline GlynRS2
  • X2 Skin Designer
« Reply #31 on: January 22, 2013, 07:21:33 PM »
Yes that looks like one of my X2 skins.
I can redo it as a X3 skin if you like, just let me know which one it is.
Download all my genre icons for the Mede8er videowall from this thread (updated 05.02.2013 & includes music genre icons)
Download all my ThumbGen templates for the Mede8er by clicking here (updated 01.12.2011)
Offline brentsw3
« Reply #32 on: January 23, 2013, 08:10:57 AM »
That's very nice of you!! I believe it was the burning planet skin pack.
I actually pulled  a few to play with. This was my 1st attempt at themeing my Mede8er!
Offline hdstudio
  • X2 Skin Designer
« Reply #33 on: February 08, 2013, 09:43:53 AM »
I really love cats
Can you do cats skins for X3?
THANKS!!  ;D ;D
Offline Mike42
« Reply #34 on: February 09, 2013, 11:08:00 AM »
I really love cats
THANKS!!  ;D ;D
http://www.mede8erforum.com/index.php/topic,10403.0.html is tthis enough cat for you
Gr, mike42  ;D
Mede8er : MED1000X3D
Network: Wired CAT5
AV receiver: Onkyo TX-NR414
additional equipment:
Re: Re: Skin Pack Requests - Post them here
« Reply #35 on: February 09, 2013, 11:28:15 AM »
23 new skins by GlynRS2.for X3D. Check the skin section....
Verstuurd van mijn GT-I9300 met Tapatalk
Offline GlynRS2
  • X2 Skin Designer
« Reply #36 on: February 10, 2013, 12:39:46 PM »
I really love cats
THANKS!!  ;D ;D
Would something like this be OK?:
Should be ready soon, just testing at present.
DcR-Nl
  • Guest
« Reply #37 on: March 09, 2013, 08:19:37 PM »
GlynRS2, thank you for all your hard work.
If I may, I would like to bring a Dutch translation error to your attention. You translated "Media Library" in the X3 Evo I skin (http://www.mede8erforum.com/index.php/topic,10495.0.html) to "Media Keuza", but this should be "Media Keuze".  ;)
//edit:Posted a temp(?) fix in the original skin thread.
« Last Edit: March 10, 2013, 01:26:33 PM by DcR-Nl »
Offline angrek
« Reply #38 on: March 25, 2013, 07:53:45 PM »
Is it possible to translate the X3 Blue Eyes into Dutch ?
Angrek
Offline GlynRS2
  • X2 Skin Designer
« Reply #39 on: March 26, 2013, 05:34:43 PM »
Angrek
Is this the sort of thing you would like?:
I am just finishing testing, but should be available soon.
Offline angrek
« Reply #40 on: March 26, 2013, 06:12:52 PM »
Looks perfect, only "YouTube" in one word plse.
Thanks in advance
Angrek
Offline GlynRS2
  • X2 Skin Designer
« Reply #41 on: March 26, 2013, 06:29:46 PM »
Thank you for dpotting that. It was a typo error and not obvious to me as a non-Dutch speaker.
I will upload corrected packs.
Offline DarkAngel
« Reply #42 on: April 02, 2013, 08:34:04 PM »
Hello,
I am graphic designer and currently working on my own skin for the MED1000X3D. Works pretty good so far, but I was wondering if there is some template available containing all changeable images? Possible with a description when they are used? I still have some images that are never displayed but are available in other skin packs...
I was also wondering if there might be a little bug regarding the display of the focus rectangle image while browsing. I think the order of the images might be wrong:
right now it is:
top: folder image
middle: focus rectangle image
bottom: thumb background
Shouldn't it be:
top: focus rectangle image
middle: folder image
regards
« Reply #43 on: April 02, 2013, 08:39:05 PM »
If you like we can add you to the closed X3 Skin Designer Group.
That will give you access to more information.
Offline DarkAngel
« Reply #44 on: April 02, 2013, 08:39:59 PM »
Yes, I would like that very much!  :D
