Author Topic: Tips for Mac Users? Post them here!  (Read 46344 times)
Offline Another Dave
Re: Tips for Mac Users? Post them here!
« Reply #15 on: October 02, 2011, 08:09:16 PM »
Just want to ask if anyone has any good ideas for getting xml info onto Med500 X2. Using Dune x which is excellent but wolud love to be able to do XML at the same time. Used the wife Laptops and Y2M and export XML only but would prefer to be able to do it all form my Mac
Dave
Offline macuser
« Reply #16 on: October 02, 2011, 08:38:01 PM »
I use ACRyan Yamj http://www.acryan.com/forums/viewtopic.php?f=95&t=4210 and i copy the xml generated files to movies folders.But does not work the Genres.Mede8er can see only the sunopsis of these xml files.
Optoma HD80,Sharp LC-52DH65E, Mede8er MED1000X3D 3 TB WD green HDD -> with ethernet cat 6 to Time Capsule 3 TB, Marantz NR 1602,Apple TV2,Dune HD Duo, LG HR550, Pace DS-831,Roister HT-3300
Sharp LC-42SB55E,  Mede8er MED400X2,Yamaha YSP 800,Samsung BD C5900,Dune Lite 53D,Apple TV3
MacBook Pro, MacBook & MacPro, latest Lion OS
WD MyBookWorld II 2TB NAS Server
Offline philip122
    • http://ny.pe
« Reply #17 on: December 27, 2013, 12:16:58 PM »
For all other music files you need to use a separate tool called Tagscanner on a PC first to generate an xml file for the MED500X2 to read.
Offline philip122
    • http://ny.pe
« Reply #18 on: January 10, 2014, 12:45:24 PM »
The Mede8er devices does not currently support launching playback from remote devices, which is a functionality we know Mede8er is working on adding to the player. Once this have been added, it is planned to add both remote control functionalities, and the ability to launch movies on the Mede8er directly from the My Movies for iPhone, iPad and Android applications.
Offline kkk3
« Reply #19 on: November 28, 2014, 11:15:43 PM »
good day...
i use an iMac 21 late 2013 running on OS X Yosemite version 10.10.1
my player is a meder8er 450x2.
my question:
how do i add titles, pictures, synopsis etc, after i donwload to my harddrive and that the 450x2 can read it too
others have given me tips but i cant seem to make it work
can anyone kindly post a step by step process - ala "idots guide...."
kinda new and not very 'techkie' guy
thanks
please help.
