Author Topic: Mede8er MED400X2S won't leave home screen  (Read 3519 times)
Offline Mortal Tree
« on: February 18, 2018, 03:31:23 PM »
Hi all
My unit does not leave the home screen anymore.
It will sit with the loading icon for hours and hours when I choose Media Search, Movie Search, or Favourites.
Please advise if anyone has had this issue, and how they fixed it! Thanks a million
Offline mike_carton
  • Helpful Contribution Status: +11/-1
Re: Mede8er MED400X2S won't leave home screen
« Reply #1 on: February 18, 2018, 09:43:50 PM »
1. Did you update firmware recently? Did that go well?
2. Have you tried pulling the power plug, waiting 15 seconds and trying again?
Offline Mortal Tree
« Reply #2 on: February 20, 2018, 07:06:10 AM »
Thanks for the reply!
I have not updated firmware, no. I did a settings reset and reconfigured with no result.
I have had it off for extended periods of time, but will try the power plug tip.
Failing that, a firmware update!
