Author Topic: Mede8er 500x2 Remote and Firmware issues  (Read 2877 times)
Offline Mr V
« on: February 08, 2018, 02:02:08 PM »
Good day Guys
I would greatly appreciate some advice
I bought a used Mede8er 500x2 a while back as a secondary media player and until recently connected it up.
Once connected, I noticed that the mede8er unit doesn't respond to the keystrokes on the remote control.
I did test if the remote control is sending a transmission (Using a camera), and the transmitter does flash
Any Idea what can resolve/fix the communication problem between the remote control and the Mede8er unit ?
Also I noticed that the firmware is on V 2.1.0
What would be the Best firmware version to upgrade to, that is known to work smoothly without any issues?
Do I need to upgrade the firmware by each preceding update first, eg V 2.1.1 first, then V2.1.2 then to V 2.1.3 till the preferred version?
thank you , your expert and knowledgeable advice will be greatly appreciated
