Author Topic: MED450x2 not is dts hd ?  (Read 5694 times)
Offline laurentsteut
« on: January 20, 2018, 04:17:58 PM »
Hello, I just bought a MED 450X2, this one is connected to a amp onkoy tx-sr608 when I read a mkv aec dts hd it is noted in information but the amp displays just dts?
here is the information with the dora file. thank you in advance.
[HDMI]: ST Save_HDMI_EDID_DATA_To_Flashdisk
[HDMI]: HDMI_HPD_test_s ST
[HDMI]: HPD: _- --------------- _: LOW -: HIGH point / 0.15sec
[HDMI]: HPD voltage is steady HIGH. Sink is plugged in.
[HDMI]: TV State: _- --------------- _: OFF -: ON point / 0.15sec
[HDMI]: TV is power on steady
[HDMI]: Rx Status: _- --------------- _: OFF -: ON point / 0.15sec
[HDMI]: HDMI_HPD_test_s SP
[HDMI]: Read_EDID_s OK, save it ...
[HDMI]: EDID chksum valid !!! chksum = 0 chksum divide 256 = 0
[HDMI]: Content of EDID:
unsigned char edid_data [256] = {
0x00,0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00,0x3d, 0xcb, 0x62,0x0a, 0x00,0x00,0x00,0x00,
0x00,0x14,0x01,0x03,0x80,0x10,0x09,0x78,0x0a, 0xEE, 0x91,0xa3,0x54,0x4c, 0x99,0x26,
0x0f, 0x50,0x54,0xbd, 0xEF, 0x80,0x71,0x4f, 0x81,0x00,0x81,0x40,0x81,0x80,0x95,0x00,
0x95,0x0f, 0xb3,0x00,0x01,0x01,0x02,0x3a, 0x80,0x18,0x71,0x38,0x2d, 0x40,0x58,0x2c,
0x45,0x00,0xa0,0x5a, 0x00,0x00,0x00,0x1e, 0x66,0x21,0x50,0xb0,0x51,0x00,0x1b, 0x30,
0x40,0x70,0x36,0x00,0xa0,0x5a, 0x00,0x00,0x00,0x1e, 0x00,0x00,0x00,0xfc, 0x00,0x54,
0x58,0x2d, 0x53,0x52,0x36,0x30,0x38,0x0a, 0x20,0x20,0x20,0x20,0x00,0x00,0x00,0xfd,
0x00,0x18,0x4b, 0x1a, 0x51,0x11,0x00,0x0a, 0x20,0x20,0x20,0x20,0x20,0x20,0x01,0xd9,
0x02,0x03,0x49,0xf1,0x53,0x90,0x1f, 0x04,0x13,0x05,0x14,0x03,0x12,0x20,0x21,0x22,
0x06,0x15,0x0f, 0x1e, 0x0a, 0x19,0x24,0x26,0x38,0x09,0x7f, 0x07,0x0f, 0x7f, 0x07,0x17,
0x07,0x50,0x3f, 0x06,0xc0,0x4d, 0x02,0x00,0x57,0x06,0x00,0x5f, 0x7e, 0x01,0x67,0x54,
0x00,0x83,0x4f, 0x00,0x00,0x6c, 0x03,0x0c, 0x00,0x12,0x00,0xb8,0x2d, 0xc0,0x00,0x00,
0x00,0x00,0xe3,0x05,0x03,0x01,0xe2,0x00,0x0f, 0x01,0x1d, 0x00,0x72,0x51,0xd0,0x1e,
0x20,0x6e, 0x28,0x55,0x00,0xa0,0x5a, 0x00,0x00,0x00,0x1e, 0x01,0x1d, 0x00,0xbc, 0x52,
0xd0,0x1e, 0x20,0xb8,0x28,0x55,0x40,0xa0,0x5a, 0x00,0x00,0x00,0x1e, 0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb4 ,?};
[HDMI]: Save_HDMI_EDID_DATA_To_Flashdisk SP
Re: MED450x2 not is dts hd ?
« Reply #1 on: January 20, 2018, 05:34:39 PM »
firmware version 3.05
« Reply #2 on: January 21, 2018, 10:11:13 AM »
That is incomplete. There should be a huge section following that saying edit revision...cea datablocks....etc,etc.
You are connected by hdmi to the amp?
« Reply #3 on: January 21, 2018, 10:50:09 AM »
yes, I am good in hdmi. If I pass a bluray with my player dd I have the dd truehd and dts hdma that appears on the screen.
With the Med 450 if I put the soundtrack dts hdma or dd true hd I'm no longer the sounds and I must put the ac3 instead of true hd but the amp goes into pcm mode ...
it could come from the fact that I'm not put hard drive in the med, and that I am with an external hard drive in normal usb? slow transfer rate?
Sorry for the mistakes I am francophone and I use a translator.
« Reply #4 on: January 21, 2018, 10:56:03 AM »
The x2 is edid driven. It will only output what the edid says is supported, and the edid you have says nothing at all.
« Reply #5 on: January 21, 2018, 11:28:27 AM »
I will install version 2.0 and re test with the dora file
« Reply #6 on: January 21, 2018, 11:46:41 AM »
here it is as an attached file
« Reply #7 on: January 21, 2018, 12:10:08 PM »
Here is the information of a film that is problematic
Général
Identifiant unique                       : 184051720833740435044631980569922403931 (0x8A771271AB94422F8E0D2B7B3A3C7E5B)
Nom complet                              : M:\MKV 1080p\FILM\San Andreas 1080p.mkv
Format                                   : Matroska
Version du format                        : Version 4 / Version 2
Taille du fichier                        : 14,7 Gio
Durée                                    : 1 h 54 min
Type de débit global                     : Variable
Débit global moyen                       : 18,3 Mb/s
Date d'encodage                          : UTC 2015-09-27 16:07:09
Application utilisée                     : mkvmerge v8.2.0 ('World of Adventure') 64bit
Bibliothèque utilisée                    : libebml v1.3.1 + libmatroska v1.4.2
Couverture                               : Yes
Attachments                              : Cover124308_front.jpg
Vidéo
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Profil du format                         : High@L4.1
Paramètres du format                     : CABAC / 5 Ref Frames
Paramètres du format, CABAC              : Oui
Paramètres du format, RefFrames          : 5 images
Identifiant du codec                     : V_MPEG4/ISO/AVC
Durée                                    : 1 h 54 min
Débit                                    : 12,0 Mb/s
Largeur                                  : 1 920 pixels
Hauteur                                  : 800 pixels
Format à l'écran                         : 2,40:1
Type d'images/s                          : Constant
Images par seconde                       : 23,976 (24000/1001) Im/s
Espace de couleurs                       : YUV
Sous-échantillonnage de la chrominance   : 4:2:0
Profondeur des couleurs                  : 8 bits
Type de balayage                         : Progressif
Bits/(Pixel*Image)                       : 0.325
Taille du flux                           : 9,55 Gio (65%)
Bibliothèque utilisée                    : x264 core 142 r2431+42 c69a006 tMod [8-bit@4:2:0 X86_64]
Paramètres d'encodage                    : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=1.05:0.10 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=11969 / ratetol=2.0 / qcomp=0.70 / qpmin=0:0:0 / qpmax=69:69:69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Langue                                   : Anglais
Default                                  : Oui
Forced                                   : Non
Audio #1
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Identifiant du codec                     : A_AC3
Durée                                    : 1 h 54 min
Type de débit                            : Constant
Débit                                    : 448 kb/s
Canaux                                   : 6 canaux
Position des cannaux                     : Front: L C R, Side: L R, LFE
Echantillonnage                          : 48,0 kHz
Images par seconde                       : 31,250 Im/s (1536 SPF)
Profondeur des couleurs                  : 16 bits
Mode de compression                      : Avec perte
Taille du flux                           : 367 Mio (2%)
Titre                                    : VFI AC3 5.1
Langue                                   : Français
ServiceKind/String                       : Complete Main
Default                                  : Oui
Forced                                   : Non
Audio #2
Format                                   : TrueHD
Profil du format                         : TrueHD+Atmos / TrueHD
Identifiant du codec                     : A_TRUEHD
Durée                                    : 1 h 54 min
Type de débit                            : Variable
Débit                                    : 5 239 kb/s
Débit maximum                            : 8 760 kb/s
Canaux                                   : Object Based / 8 canaux
Position des cannaux                     : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Echantillonnage                          :  / 48,0 kHz
Images par seconde                       : 1 200,000 Im/s (40 SPF)
Mode de compression                      : Sans perte
Taille du flux                           : 4,19 Gio (29%)
Titre                                    : VO TRUEHD 7.1
Langue                                   : Anglais
Default                                  : Non
Forced                                   : Non
Audio #3
Format                                   : AC-3
Durée                                    : 1 h 54 min
Débit                                    : 640 kb/s
Canaux                                   : 6 canaux
Taille du flux                           : 524 Mio (3%)
Titre                                    : VO AC3 5.1
Langue                                   : Anglais
Default                                  : Non
Forced                                   : Non
Texte
Format                                   : UTF-8
Identifiant du codec                     : S_TEXT/UTF8
Identifiant du codec/Info                : UTF-8 Plain Text
Durée                                    : 1 h 45 min
Débit                                    : 35 b/s
ElementCount                             : 990
Taille du flux                           : 27,6 Kio (0%)
Titre                                    : FR Complet
Langue                                   : Français
Default                                  : Non
Forced                                   : Non
Menu
00:00:00.000                             : en:00:00:00.000
00:09:29.944                             : en:00:09:29.944
00:18:47.209                             : en:00:18:47.209
00:30:10.100                             : en:00:30:10.100
00:40:08.823                             : en:00:40:08.823
00:50:18.098                             : en:00:50:18.098
00:59:44.498                             : en:00:59:44.498
01:11:27.366                             : en:01:11:27.366
01:19:43.612                             : en:01:19:43.612
01:30:40.810                             : en:01:30:40.810
01:39:56.490                             : en:01:39:56.490
01:47:10.924                             : en:01:47:10.924
« Reply #8 on: January 21, 2018, 12:14:14 PM »
here is another one, I wonder if the coding of the movie is good of the hd?
Caractéristiques du transfert            : BT.709
Coefficients de la matrice               : BT.709
Audio #1
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Identifiant du codec                     : A_DTS
Durée                                    : 2 h 11 min
Débit                                    : 768 kb/s
Canaux                                   : 6 canaux
Images par seconde                       : 93,750 Im/s (512 SPF)
Profondeur des couleurs                  : 24 bits
Taille du flux                           : 720 Mio (5%)
Titre                                    : Audio French (VFF)  DTS 5.1 channels 24 bits @ 768 Kbps cbr - Source BD REMUX Z2 WiHD (Thx to plissken) ^^
Langue                                   : Français
Default                                  : Oui
Forced                                   : Oui
Audio #2
Format                                   : DTS
Profil du format                         : MA / Core
Durée                                    : 2 h 11 min
Type de débit                            : Variable / Constant
Débit                                    : Inconnu / 1 509 kb/s
Canaux                                   : 6 canaux
Mode de compression                      : Sans perte / Lossy
Titre                                    : Audio Eng DTS-HD MA 5.1 channels 24 bits @ 4210 Kbps abr (PROPER car nouvelle piste DTS-HD MA)
Langue                                   : Anglais
Default                                  : Non
Forced                                   : Non
Texte #1
Format                                   : UTF-8
Titre                                    : Sous-titres Fr Forces [BD Z2]
Langue                                   : Français
Default                                  : Oui
Forced                                   : Oui
Texte #2
Format                                   : UTF-8
Titre                                    : Sous-titres Fr Complets [BD Z2]
Langue                                   : Français
Default                                  : Non
Forced                                   : Non
Texte #3
Format                                   : UTF-8
Titre                                    : English Hearing Impaired Subtitles [BD Z1]
Langue                                   : Anglais
Default                                  : Non
Forced                                   : Non
Texte #4
Format                                   : UTF-8
Titre                                    : Full Eng Subtitles - edited from H.I. [BD Z1]
Langue                                   : Anglais
Default                                  : Non
Forced                                   : Non
Menu
00:00:00.000                             : en:Chapter 01
00:04:21.011                             : en:Chapter 02
00:10:19.118                             : en:Chapter 03
00:15:35.268                             : en:Chapter 04
00:19:18.574                             : en:Chapter 05
00:24:32.721                             : en:Chapter 06
00:30:23.405                             : en:Chapter 07
00:36:28.478                             : en:Chapter 08
00:44:01.305                             : en:Chapter 09
00:50:50.255                             : en:Chapter 10
00:56:54.327                             : en:Chapter 11
01:04:54.057                             : en:Chapter 12
01:10:14.293                             : en:Chapter 13
01:19:13.457                             : en:Chapter 14
01:25:41.178                             : en:Chapter 15
01:34:53.771                             : en:Chapter 16
01:41:48.561                             : en:Chapter 17
01:48:31.838                             : en:Chapter 18
01:57:48.812                             : en:Chapter 19
02:03:04.418                             : en:Chapter 20
« Reply #9 on: January 21, 2018, 12:17:03 PM »
a third
Général
Identifiant unique                       : 144879473688458514704213893590071277245 (0x6CFEC58C306B5EB854AD27635A2E76BD)
Nom complet                              : M:\MKV 1080p\FILM\Taken 3 1080p EXTENDED.mkv
Format                                   : Matroska
Taille du fichier                        : 14,2 Gio
Durée                                    : 1 h 55 min
Débit global moyen                       : 17,7 Mb/s
Nom du film                              : TAKEN 3 2014 EXTENDED VFF 1080P UTT   :-))    What else !!!
Date d'encodage                          : UTC 2018-01-21 09:44:14
Application utilisée                     : mkvmerge v20.0.0 ('I Am The Sun') 64-bit
Bibliothèque utilisée                    : libebml v1.3.5 + libmatroska v1.4.8
Vidéo
Format                                   : AVC
Durée                                    : 1 h 55 min
Débit                                    : 14,0 Mb/s
Images par seconde                       : 24,000 Im/s
Bits/(Pixel*Image)                       : 0.380
Taille du flux                           : 11,3 Gio (79%)
Titre                                    : Release UTT x264, 2pass, profile High, level 4.1
Bibliothèque utilisée                    : x264 core 144 r2525 40bb568
Paramètres d'encodage                    : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=6,6 / fast_pskip=0 / chroma_qp_offset=-2 / threads=16 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=2 / keyint=240 / keyint_min=22 / scenecut=40 / intra_refresh=0 / rc_lookahead=240 / rc=2pass / mbtree=1 / bitrate=14000 / ratetol=1.0 / qcomp=0.75 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=2:1.00
Langue                                   : Anglais
Default                                  : Oui
Forced                                   : Non
Gamme de couleurs                        : Limited
Coordonnées de chromaticité              : BT.709
Audio
Format                                   : DTS
Durée                                    : 1 h 55 min
Débit                                    : 3 675 kb/s / 1 509 kb/s
Canaux                                   : 6 canaux
Taille du flux                           : 2,96 Gio (21%)
Titre                                    : VFF, DTS Master Audio, 5.1 channels, 24 bits, 48kHz, 3675kbps
Langue                                   : Français
Default                                  : Oui
Forced                                   : Non
Texte #1
Format                                   : UTF-8
Durée                                    : 1 h 18 min
Débit                                    : 0 b/s
ElementCount                             : 8
Taille du flux                           : 225 Octets (0%)
Titre                                    : VFF FORCES
Langue                                   : Français
Default                                  : Oui
Forced                                   : Non
Texte #2
Format                                   : UTF-8
Durée                                    : 1 h 54 min
Débit                                    : 34 b/s
ElementCount                             : 1234
Taille du flux                           : 29,2 Kio (0%)
Titre                                    : VFF COMPLETS
Langue                                   : Français
Default                                  : Non
Forced                                   : Non
Menu
00:10:19.042                             : en:00:10:19.042
00:18:31.083                             : en:00:18:31.083
00:29:17.375                             : en:00:29:17.375
00:38:43.833                             : en:00:38:43.833
00:50:24.958                             : en:00:50:24.958
00:59:10.583                             : en:00:59:10.583
01:07:16.667                             : en:01:07:16.667
01:18:12.333                             : en:01:18:12.333
01:29:56.250                             : en:01:29:56.250
01:39:42.375                             : en:01:39:42.375
01:49:42.083                             : en:01:49:42.083
« Reply #10 on: January 21, 2018, 12:37:13 PM »
It is a problem of coding of the film, I have just tested a file (see information below) and the amp to display DD true HD.
i'm going to try dts hdma
Paramètres du format                     : CABAC / 4 Ref Frames
Paramètres du format, RefFrames          : 4 images
Durée                                    : 11s 11 ms
Hauteur                                  : 1 080 pixels
Format à l'écran                         : 16/9
Bibliothèque utilisée                    : x264 core 146 r2538 121396c
Paramètres d'encodage                    : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=15.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=30000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Langue                                   : Anglais
Default                                  : Non
Forced                                   : Non
Audio
Format                                   : TrueHD
Durée                                    : 11s 11 ms
Débit maximum                            : 6 423 kb/s
Canaux                                   : 8 canaux
Position des cannaux                     : Front: L C R, Side: L R, Back: L R, LFE
Titre                                    : Surround 7.1
Langue                                   : Anglais
Default                                  : Oui
Forced                                   : Non
« Reply #11 on: January 21, 2018, 12:45:31 PM »
ok for the following file in dts hdma
Général
Identifiant unique                       : 221710155216558908250019548894002179207 (0xA6CBD29BDA6C0AB9A311F59A17E86C87)
Nom complet                              : J:\dts_living_world_of_audio_v1_lossless_1080p-thedigitaltheater.mkv
Format                                   : Matroska
Taille du fichier                        : 139 Mio
Durée                                    : 49s 56 ms
Débit global moyen                       : 23,8 Mb/s
Date d'encodage                          : UTC 2015-04-06 11:34:34
Application utilisée                     : mkvmerge v6.9.1 ('Blue Panther') 64bit built on Apr 18 2014 18:23:38
Bibliothèque utilisée                    : libebml v1.3.0 + libmatroska v1.4.1
Vidéo
Format                                   : AVC
Durée                                    : 49s 49 ms
Langue                                   : Anglais
Default                                  : Oui
Forced                                   : Non
Audio
Format                                   : DTS
Durée                                    : 49s 56 ms
Canaux                                   : 8 canaux / 6 canaux
Position des cannaux                     : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Echantillonnage                          : 96,0 kHz / 48,0 kHz
Langue                                   : Anglais
Default                                  : Oui
Forced                                   : Non
« Reply #12 on: January 21, 2018, 12:59:02 PM »
I do not understand anything, I just tested and now it works ???? but with the firmware 2.0 .... I put the last?
« Reply #13 on: January 21, 2018, 01:53:17 PM »
Firmware 3.0.5 delivered and everything works. I do not understand what is going on ..
« Reply #14 on: January 21, 2018, 08:56:43 PM »
The edid capture is not telling you data in the players firmware. It is telling you about the data transferred from the amp to the player on boot. Before upgrading the firmware you where getting no such data transfer. Now you cleared the transfer problem all firmware should get the data.
