Author Topic: MKV-files  (Read 3835 times)
Offline RobinM
MKV-files
« on: December 21, 2017, 01:29:08 PM »
Another post, however now in English.. I noticed that I put my question in Dutch, smart guy huh?  :P
Anyway, I have read a lot about the use of mkv files on the Mede8er, but something is not entirely clear to me.
If I understand correctly, should you be able to play MKv files with the med500x2?
I understand that if the resolution is too high, that it does not work, experienced that myself.
However when I want to play a mkf file with a lower resolution, the Mede8er doesn't display the file via TV.  On the PC it will though.
For the info: I use my med500x2 with 3tb as follows: I connect it to the computer via the USB connection, put films / series on it and put it at the TV that I connect via HDMI and watch it.
Don't I understand somethingt, or am I doing something wrong ...?
Thanks for the comments!
Offline rommy66
Re: MKV-files
« Reply #1 on: December 23, 2017, 06:05:38 PM »
Bro, I have also MED500X2 and all my collection of movies and series are 720p and 1080p and I haven't any problems to watch movies in FullHD resolution (1920x1080dpi) ;)
If you have a problems, install latest version of firmware for MED500X2.
Offline RobinM
Re: MKV-files
« Reply #2 on: December 24, 2017, 09:51:32 AM »
I have Installed the latest version, and I can play a lot of stuff which came to me a while back. However it's these mkv files which are making me use the laptop in front of the tv :/
Re: MKV-files
« Reply #3 on: December 24, 2017, 02:05:26 PM »
Check the codec.
https://mediaarea.net/en/MediaInfo
The codec takes priority over the container.
Offline mike_carton
  • Helpful Contribution Status: +11/-1
Re: MKV-files
« Reply #4 on: January 05, 2018, 06:43:00 PM »
If you're still having problems, please use MediaInfo application https://mediaarea.net/en/MediaInfo
You can post here the "text" version of that application's analysis of your problematic mkv file and we can go from there.
