Author Topic: Episode shows episodes AND image  (Read 8137 times)
Offline Sweder
« on: November 19, 2017, 07:14:14 AM »
I used TVrename to download images for my episodes. All seemed to work well.
When looking with my Mede8er, the episode folder view shows the episodes and the images as seperate tiles. Did I do something wrong?
Also, the series folder does not have an image, only xml files.
Offline LarryM8
Re: Episode shows episodes AND image
« Reply #1 on: November 19, 2017, 01:09:29 PM »
Which version are you using? 2.3b1 or 2.3b2 ?
2.3b1 has bugs downloading some images.
« Last Edit: November 19, 2017, 06:27:00 PM by LarryM8 »
« Reply #2 on: November 19, 2017, 05:49:56 PM »
Turn on Autoview on the X3D.
Offline Sweder
« Reply #3 on: November 22, 2017, 04:33:12 AM »
@LarryM8 I am using the latest version taken from the TVRename download page, i.e. 2.3b1
The images are downloaded. But when selecting a season on the Mede8er, there are separate tiles for movie file and image file.
Offline Sweder
« Reply #4 on: November 22, 2017, 04:36:54 AM »
@Jer1956 when switching on AutoView I get a list of folders, seasons, and files instead of tiles. It still shows image and movie files.
It used to be that it would only show movie files, using the image file to display in the tile.
Any thoughts?
Offline LarryM8
« Reply #5 on: November 22, 2017, 06:07:29 PM »
Hi Sweder,
there is a new version https://groups.google.com/d/msg/tvrename/AxTKFA6fpKQ/OFtSdoMeBAAJ
To change the display in the Mede8er go to the season directory, press the menu button and choose to display not "All Media" but "Movies".
And be sure TVRename is configured to not generate a series.jpg file.
Offline Sweder
« Reply #6 on: December 28, 2017, 03:00:22 AM »
Solution found. 2 things need to be done.
Step 1
It turns out that the view.xml file in the Season folder itself is not correct. It should have this content:
<?xml version="1.0" encoding="UTF-8"?>
<FolderTag>
  <ViewMode>Photo</ViewMode>
  <ViewType>Video</ViewType>
</FolderTag>
Step 2
