Author Topic: Stream FM radio from smartphone to Med600X3D ?  (Read 5709 times)
Offline karine
« on: September 19, 2017, 04:08:39 PM »
Is there a way to stream FM radio from a smartphone to a Med600X3D ?
Possible streaming radio from a smartphone whith Google Chrome to Med600X3D ?
Re: Stream FM radio from smartphone to Med600X3D ?
« Reply #1 on: September 20, 2017, 08:48:31 AM »
Most FM channels have digital streaming services. Why can't you find it via the internal streaming radio?
Offline karine
« Reply #2 on: September 21, 2017, 07:28:34 PM »
I wanted to play it on my amplifier via the Med60000X3D.
I have now bought a Bluetooth module and stream it to the amplifier.
« Reply #3 on: September 21, 2017, 07:46:46 PM »
Yes, but the player has it's own digital radio client. Most amps do have as well. There is no need to restream FM.
Offline karine
« Reply #4 on: September 21, 2017, 07:50:46 PM »
Yes, but each time you turn on the TV to select a music station.
« Reply #5 on: September 21, 2017, 07:58:04 PM »
To stream you should use digital radio sources and push to the players DMR, without the TV on.
Offline karine
« Reply #6 on: September 21, 2017, 07:59:34 PM »
Can you give an example of this?
« Reply #7 on: September 21, 2017, 08:04:16 PM »
https://play.google.com/store/apps/details?id=com.upnp.upnpctrl
That is an example. You need to find a phone app like that.
« Reply #8 on: September 21, 2017, 08:19:39 PM »
Is your phone IOS based? That is more of a problem.
Offline karine
« Reply #9 on: September 22, 2017, 08:45:49 PM »
It's Android.
« Reply #10 on: September 23, 2017, 08:43:46 AM »
Then you will find many DLNA apps in the Store which can stream to the DMR without the TV needing to be on.
https://play.google.com/store/search?q=dlna%20radio&c=apps
« Last Edit: September 23, 2017, 08:59:32 AM by jer1956 »
Offline karine
« Reply #11 on: September 24, 2017, 06:53:05 PM »
OK, thank you for the tip.
