Author Topic: Missing Icons Movies on Home page  (Read 7363 times)
Offline Lucsi
« on: November 18, 2014, 08:36:33 PM »
Hello All,
i installed a new MED400X2S and Missing Movies Icon from the Home page
I tried all version upgrade up to the last version Beta included
I have Favourites
Media Library
Internet
Setup
All my movies are on a shared network, I can Browse and able to play directly from the file as from any file manager but i have no database as such,
I added the folder to FAV than did a browse folder same outcome
What am I'm doing wrong
Many thanks
Lucsi
Re: Missing Icons Movies on Home page
« Reply #1 on: November 18, 2014, 08:45:57 PM »
Suggest you start to read here:
Especially movie and tv scraper guide.
Offline Lucsi
« Reply #2 on: November 18, 2014, 09:13:15 PM »
Thank you for the reply
I have V3.0.4 now and this is guide is for V4 I cannot detect nowhere the download for it
Do I need internal or External HDD to use this Meder please?
All my movies over 2000 are on different folders and different NAS Drives
Do I need do download further applications for the wall / movie info?
Many thanks
LUcsi
« Reply #3 on: November 18, 2014, 09:40:28 PM »
He wasn't implying you start at the top. There are guides for other models in there.
With multiple sources yoiu need Jukebox+. That requires you to make med jukebox of the media on each source in the first place using the movie scan/scraper.
Offline Lucsi
« Reply #4 on: November 19, 2014, 11:53:09 AM »
Hello All thank you for the reply
Is anywhere I can find a step by step how to enable jukebox on MED400X2S
I read some of the files sent but i am missing options
I purely like to have a wall of movies and stream from multiple NAS devices mainly IOMEGA.
I noted that subtitles NOT downloading automatically, I must download manually and put it in the folder with same name, Am I correct?
I would like not to reinvent how do be done if possible because my requirement is very simple, "Enjoy the movies"
Many thanks for some simple answer
Lucsi
Offline Tattuzuzi
« Reply #5 on: August 17, 2015, 09:06:19 AM »
I read that you posted and try to understand the whole story and thought it was fantastic.
