Author Topic: Feedback for V3.0.5 - 20Oct2014 Beta for ME500X2, MED450X2/S, MED400X2/S New  (Read 8555 times)
Offline TifKag
  • X2 Skin Designer
In my opinion, the 3.0.5 from the 12th was more responsive.
With the original skin, i have a graphic issue.
When i have an USB Device attached, and want to remove it with the Green button, i get the window where it says Cancel and the name of the USB device.
But that window has a purple color.
But when i install a skin that has loaded a different background, the USB removal window is black as it should be ?
That issue is with both 3.0.5 versions. (3.0.4 is Fine)
BTW: I always do a clean install with new or old FW (Like the Emergency procedure)
« Last Edit: October 20, 2014, 03:35:20 PM by TifKag »
Offline Froebel
Just being curious here; is this version build on an updated SDK since 3.0.4
I found one translation error: within the setup menu, the "misc." page is translated into Dutch as "Diverse", this should be "Diversen", maybe "Overig" would be even better.
Keep up the good works!
MED500X2 V3.0.5
 - HDD 1TB Samsung HD103SI
 - HDMI to JVC LT-32X70SU LCD (HDMI2)
 - COAX to BOSE 3.2.1 GS II
 - Wired Network, Devolo dLAN 500Mbps AVPlus,
 - Internet Access, tp-link tl-wr1043nd (running Open-WRT), Ubee Docsis 3 Cable modem
 - Audio, Photo and TV-Series on Synology DS-209+II (running DSM 4.2, all volumes NFS mounted) Movies on 2TB eSATA,. TV Series on 3TB USB
Offline daL
Based on Tifkag's response to be honest I don't dare to install this second beta. My x5002 and the ones of 2 friends are really very fast now thanks to beta 1, no doubt!!
Although I'm willing to test beta 2, I need the old fw (beta 1) in case I loose the responsiveness...
Is beta 1 still downloadable?
Regards,
daL
Offline lebans
Offline Ronaldk
Thank you for the more responsive interface.  ;D
I note that the display overlay bug of the fanart in the TV-series view is still there. More detail of the issue can be found here:
http://www.mede8erforum.com/index.php/topic,14461.new.html#new
I also noted that the "flickr" option is still showing in the screensaver menu. It was communicated in the past it is no longer supported. Has this been resolved (i.e. fixed) or is it a left over function that has not been removed from the options interface?
Amplifier: Pioneer SC-LX57
Offline daL
Locked new release
