Author Topic: Creston IP control  (Read 49640 times)
Offline mingxiu
Re: Creston IP control
« Reply #15 on: September 06, 2015, 06:50:13 AM »
Hi, can someone also please add me to the board.
looking to control two 600 and one 1000 through ip, or am I looking in the wrong direction?
thanks
Offline matthall
  • B8a Tester - X3D NET API
« Reply #16 on: January 12, 2016, 05:11:09 PM »
Please could I also be added to the NetAPI sections.
I'm also a Crestron programmer.
Thanks,
Matt
« Reply #17 on: January 12, 2016, 05:32:24 PM »
done
Offline mede8er1760
« Reply #18 on: January 23, 2016, 10:11:04 AM »
Good morning,
I want to build a customized app to remote my Mede8er 500X via webremote/IP commands, but can't find an overview of the commands.
Any help where to find those ?
Thanks !
« Reply #19 on: January 23, 2016, 01:02:55 PM »
Good morning,
Thanks !
There is no ip command api for 500X, that only will work with the X3 series players.
Offline mede8er1760
« Reply #20 on: January 23, 2016, 01:44:17 PM »
Sorry for my unclear request ... I'm actually looking for the commands that are send over port 1024, to build my own app.
Thanks again !
« Reply #21 on: January 23, 2016, 01:54:54 PM »
You have an X3D player then and not a 500X?
Offline mede8er1760
« Reply #22 on: January 23, 2016, 02:03:34 PM »
500X. I'm currently using the Mede8erRemote.apk from post below post
http://www.mede8erforum.com/index.php/topic,4624.0.html
But because there are some buttons not working or with wrong commands, I want to decompile, adjust and compile it again.
Thanks !
Offline mede8er1760
« Reply #23 on: January 23, 2016, 02:33:53 PM »
There are 2 of the main features that don't work.
Rewind button does FastForward
FastForward button does nothing
I tried this on multiple android devices with the same result.
Also posted this question in http://www.mede8erforum.com/index.php/topic,4624.0.html but no answer till now.
« Reply #24 on: January 23, 2016, 05:05:36 PM »
Here the  Web Remote commands for X3D but most should be the same for X1 Series
(ENTER)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_SELECT
(HOME)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_GUIDE
(RETURN)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_RETURN
(NAV UP)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_UP
(NAV LEFT)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD LEFT
(NAV DOWN)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_DOWN
(NAV RIGHT)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_RIGHT
(MENU)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_MENU
(EDIT)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_EDIT
(SETUP)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_SETUP
(AUDIO MUTE)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_MUTE
(VOL DOWN)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_VOL_DOWN
(VOL UP)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_VOL_UP
(FAST BACK)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_FRWD
(FAST FORWARD)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_FFWD
(PLAY/PAUSE)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_MELE_PLAYPAUSE
(BACK SKIP)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_PREV
(FORWARD SKIP)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_NEXT
(STOP)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_STOP
(DIGIT1)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_ONE
(DIGIT2)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_TWO
(DIGIT3)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_THREE
(DIGIT4)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_FOUR
(DIGIT5)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_FIVE
(DIGIT6)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_SIX
(DIGIT7)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_SEVEN
(DIGIT8)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_EIGHT
(DIGIT9)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_NINE
(DIGIT0)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_ZERO
(AB REPEAT)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_AB_REPEAT
(GOTO)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_SEARCH
(TV SYS)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_PSCAN
(FILE MANAGER)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_FILE_COPY
(MUSIC PLAYLIST)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_MELE_MUSIC
(DEVICES PAGE)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_FORCE_BROWSER
(REPEAT)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_REPEAT
(ZOOM)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_ZOOM
(ANGLE)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_ANGLE
(INFO)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_DISPLAY
(AUDIO)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_AUDIO
(SUBTITLE)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_STITLE
(VIEW) - zpl to add
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_VIEW
(FUNCTION F1) - zpl to add
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_F1
(FUNCTION F2) - zpl to add
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_F2
(FUNCTION F3) - zpl to add
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_F3
(FUNCTION F4) - zpl to add
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_F4
(OFF) - zpl to add
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_OFF
(STANDBY)  - suggest 'stop' then command 'CMD_DISCREET_OFF'
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_DISCREET_OFF
(STANDBY WAKE UP)
IP:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_DISCREET_ON
Example - 'Enter'
192.168.0.11:1024/cgi-bin/cubermctrl.cgi?id=1&cmd=CMD_SELECT
Offline mede8er1760
« Reply #25 on: January 23, 2016, 06:47:12 PM »
Fantastic, exactly what I was looking for and works like a charm !!!!  8) 8) 8)
