Author Topic: Feedback for - V3.0.2 - 18Feb2014 for ME500X2, MED450X2/S, MED400X2/S XXX Latest  (Read 20068 times)
Offline Yeasis
I Love this update, 3.0.2 looks great so far (using ThatTheme! by Lock).
Device looks pretty smooth using this theme.
Only things missing (could use improvements):
- Newer Transmission version (got more options)
- Netflix support
- Auto subtitle downloads (most important imo)
Thanks for all the great work!
Offline Bertjuhh66
An old issue is still present...Pausing an serie for a while and then resume turns off the subtitles.
Offline PCoetzee24
After upgrading my 500x2 to 3.0.2 my pin protection is on and the passcode is not 0000. How do I switch it off?
Reinstall again and use recovery install mode without config restore after install.
Offline grandinj
This release freezes up every couple of days.
Previously I was running the 3.0.0 release and that had no such problems.
Normally it freezes up while navigating around the filesystem.
It requires a complete power cycle to fix - using the remote will not restart it.
I would suggest to connect your mede8er to a pc by usb cable and do a filesystem check on the disk. You probably have file system issues.
After that, use the USB Disk Ejector http://quickandeasysoftware.net/software/usb-disk-ejector tool before removing the usb cable from your pc.
I am pretty sure your instability has something todo with that.
Do this asap as every time power cycling will only further corrupting your filesystem. Fix the root cause asap.
Offline Arie.
How i can use the mede8er for netflix?
When support the mede8er firmware netflix?
