Author Topic: a good site for film and tv show front covers...  (Read 14590 times)
Offline TsChris
« on: September 18, 2013, 07:22:55 PM »
Hello does anybody know a good site for movie and tv show covers.
Offline eentje
Re: a good site for film and tv show front covers...
« Reply #1 on: September 18, 2013, 07:35:30 PM »
movies:
http://www.themoviedb.org/
tvshows: thetvdb.com
www.thetvdb.com contributor
Offline TsChris
« Reply #2 on: September 23, 2013, 07:34:49 AM »
Cheers for that eentje, was getting those for a little while as i have fell back a bit lol. do you know of a good site for about. images with film info etc.
Offline eentje
« Reply #3 on: September 23, 2013, 08:05:05 AM »
i am using thumbgen to create movie sheets with film info. i will fetch movie info from various movie sites.
currently the thumber creator is working on a fix for the movietb. so it might be a few days thill that works correctly.
if u own a x3d player u can use the build in scraper for that
« Reply #4 on: September 23, 2013, 10:34:58 AM »
There is  no site...that  is the product you  get using a med compatible scraper from  simpler images.
TV Series can't use "abouts" anyway.
Offline TsChris
« Reply #5 on: September 23, 2013, 05:52:51 PM »
is thumbgen easy to use, as I have tried a couple and found not user friendly. I plan on getting a med 1000x3d next year.
« Reply #6 on: September 24, 2013, 09:59:15 AM »
The x3d series  now has an internal scraper....
Offline TsChris
« Reply #7 on: September 25, 2013, 07:58:22 PM »
Is It any good, is it just about. files it does or front covers aswell.
« Reply #8 on: September 25, 2013, 08:42:56 PM »
Look at this:
And this:
to get an idea what you will get.
It is looking pretty damm nice and is pretty easy to use.
