Author Topic: TVRename - Tv Wall application  (Read 250254 times)
Offline Zakkie
  • Moder8or
Re: TVRename - Tv Wall application
« Reply #30 on: March 11, 2013, 04:29:55 PM »
Hi JohnWB,
For piracy reasons I need to leave that guide out of the tutorial and this forum.
I need to respect the Mede8er forum and it's rules. Please understand that the Tutorial was to help Mede8er users with the TV Wall only.
just a pointer in that direction:
You need to install a Torrent client first to enable Auto downloading of episodes.
There are many tutorials on the web which covers this, a good place to start is: http://tvrename.com/
Check out the user guide and forum.
Regards,
Zakkie.
Offline Zakkie
  • Moder8or
« Reply #31 on: March 11, 2013, 04:40:19 PM »
Hi DcR-Nl,
Thank you for the positive feedback.
If a legit TV series doesn't exist on the TVDB, you are more than welcome to create it there..click the link 'add new series'
You first need to register as a user to add what's needed, synopsis, artwork...etc.
There is a guide to the sizes of Posters, Banners, Fanart etc.: http://www.thetvdb.com/wiki/index.php/Category:Images
When done, go to TVrename and do a refresh on that series and it will pick up all the required info.
In this way other users benefit as well.
Kind regards
Zakkie
Offline JohnWB
« Reply #32 on: March 11, 2013, 06:19:31 PM »
Hi JohnWB,
Regards,
Zakkie.
Thanks for that, I take your point
« Last Edit: March 12, 2013, 08:38:06 AM by JohnWB »
Sony KDL-50W829B, Marantz SR7010, Panasonic BD35, Logitech Elite, Virgin V6, Mission 752, Mission 75C, Wharfedall 9.0, BK XLS200 Mk 2, iPhone 6S, Synology 214Play, Wetek Play2, Mede8er MED600X3D, Amazon Fire Stick, Apple TV2, NowTV, Airport Extremes
Offline demonrecords
« Reply #33 on: March 12, 2013, 07:13:18 AM »
If the episodes cannot be in separate folders, thus not having an own 'about' picture with the correct 'videoimage' for every episode, it's kinda worthless.
Why do you keep on watching the porno after you came?
Offline RobinC
« Reply #34 on: March 12, 2013, 08:40:37 AM »
well it's kinda not. Yes I would like episode specific images but at least now I'm getting fan art, proper organisation in terms of Series & Season, watched indicators and probably most importantly episode specific plots.
The lack of episode images would certainly be the icing on the cake but its omission certainly doesn't make it worthless.
« Reply #35 on: March 12, 2013, 09:18:33 AM »
I think you missed a big point here.   If your willing  to have every episode in their own folders you just use Jukebox.  The TV Wall was created for those who had previously used other devices where they could store  multiple episodes in single per season folders. That is not  supported by Jukebox...yet. It looks like we will have to look at this again due to Aggregation....as it may well be easier to offer Aggregated TV support via Jukebox then inventing a whole new system just for TV Wall.
« Reply #36 on: March 12, 2013, 09:57:43 AM »
Quote from: RobinC
That's what I'm doing manually, although more work, but I have it EXACTLY the way I want.
True for those who had previously used other devices, can be a pain to redo everything from scratch. I bought the new Dune HD Base 3D, and after fiddling around with Zappiti for 2 weeks, I gave up, as I would have to change all of my folders and structures, because of the previous use of the 500X2, which I intended to keep for further usage.
So after thinking it over, I eventually sold my Dune again, and bought the 600X3, that way, I will use 2 Mede8er devices in the house, and can keep the same structure on my NAS, plus I wouldn't have to do everything twice, once for the Jukebox, and once for Zappiti.
Offline Zakkie
  • Moder8or
« Reply #37 on: March 12, 2013, 03:58:15 PM »
Hi demonrecords,
The App is really designed for users with a large collection of Series and need a one click solution.
I update my series daily and it takes a few minutes to process and catalogue.
Also take South Park (one of my big shows)...currently sitting at 239 episodes would mean 239 additional directories, that is honestly a lot of directories to processes using your method. TVrename did this in under a minute (synopsis for each episode and all the images).
I know you have a preference to the folder per episode structure but try doing one of your shows with this App. It really does look good and functions well.
« Reply #38 on: March 13, 2013, 05:52:42 AM »
I don't have any problem now anymore doing it manually, as most of my stuff has already been done, and only adding single episodes from time to time is quite fast.
I know all the work that is behind, as I also had to do my Simpsons series collection, which is now 23 seasons long, takes a while with YAMJ.
Btw, I saw in the beginning of your tutorial that it even uses the same folder picture for every season, is that so? I have a different picture for every season (done manually of course). All my series have a picture, then every season of that series uses a different picture, and then every episode of one series uses the same picture.
So in your case, using your program, what's happening when you're on one episode and press the INFO button? I guess there comes the folder icon with the full name of the movie? And there's exactly where I want to have my about picture ;-)
But anyway, very nice work so far you did with the program, 2 thumbs up!!
Offline Froebel
« Reply #39 on: March 13, 2013, 08:34:08 AM »
Installed TVRenamer 2.2.4 and think its a great app.
However, when following the forum tutorial, I found that I'm missing a tab under preferences: Media Center.
Where I can set Mede8er compatibility.
t's just not there.
What am I missing? Any help welcome...
MED500X2 V3.0.5
 - HDD 1TB Samsung HD103SI
 - HDMI to JVC LT-32X70SU LCD (HDMI2)
 - COAX to BOSE 3.2.1 GS II
 - Wired Network, Devolo dLAN 500Mbps AVPlus,
 - Internet Access, tp-link tl-wr1043nd (running Open-WRT), Ubee Docsis 3 Cable modem
 - Audio, Photo and TV-Series on Synology DS-209+II (running DSM 4.2, all volumes NFS mounted) Movies on 2TB eSATA,. TV Series on 3TB USB
Offline Zakkie
  • Moder8or
« Reply #40 on: March 13, 2013, 10:46:13 AM »
Hi froebel,
Did you download the latest version?
You will find the link in the first post + the link for the updated tutorial
Regards
Zakkie
Offline JohnWB
« Reply #41 on: March 13, 2013, 10:57:23 AM »
if you have set up your folders with the origional beta version, can you run the latest version to get the fan art etc or would you have to remove the existing xlm & folder pictures
Offline Zakkie
  • Moder8or
« Reply #42 on: March 13, 2013, 11:12:32 AM »
Hi JohnWB
Just delete the .Jpg files....then do a 'Force Refresh All' (found under the tools menu) before doing a scan.
Regards
Zakkie
Offline JohnWB
« Reply #43 on: March 13, 2013, 11:22:39 AM »
Hi JohnWB
Regards
Zakkie
Thanks for that Zakkie, keep up the good work   :)
Offline Froebel
« Reply #44 on: March 13, 2013, 05:12:43 PM »
Zakkie, this makes a big difference indeed
TVRename 2.4.4 from the Internet is different than the offered in this topic.
Cheers!
MED500X2 V3.0.5
