Author Topic: TVRename - Tv Wall application  (Read 281745 times)
Offline Zakkie
  • Moder8or
« on: March 09, 2013, 12:07:24 PM »
Dear TVrename users.
TVrename has been updated, this is a critical update:
Now fetches data from thetvdb.com using their new JSON API.  The old XML one is being disabled soon.
Download link:
https://groups.google.com/forum/#!topic/tvrename-releases/k97p1r1IMWE
Kind regards
Zakwaan
« Last Edit: August 31, 2017, 05:13:07 PM by Zakkie »
MaxKnall
  • Guest
Re: TVRename - Tv Wall application
« Reply #1 on: March 09, 2013, 06:15:23 PM »
Thanks for this program. I have the med600x3d now for 2 weeks and it is a really nice media player.
At the moment i use it for watching tv shows and with this tool (i used the beta version from here) it is easy to organize them.
For those currently using the older version: Replace the old exe file with the new one.
Also please note that you will need to do a full refresh to turn on season specific images.
I used "Tools -> Force Refresh All" but my folder.jpg within the seasons folders don't update. Is there another way to force an update for the images?
Offline Zakkie
  • Moder8or
« Reply #2 on: March 09, 2013, 06:20:03 PM »
Hi MaxKnall,
The App picks up that the images exists and ignores it.
You need to delete the existing images and it will be replaced with the new ones.
MaxKnall
  • Guest
« Reply #3 on: March 09, 2013, 06:31:18 PM »
Ah that did it. I deleted all .jpg with a script and now i have matching images for every season. Thanks.
Offline Zakkie
  • Moder8or
« Reply #4 on: March 09, 2013, 06:49:14 PM »
You welcome!
Offline RobinC
« Reply #5 on: March 09, 2013, 07:56:21 PM »
I've been using this app for about a month now and can heartily recommend it to anyone with a Mede8er. Very easy to use and works well
Offline starwarsclark
« Reply #6 on: March 09, 2013, 08:39:52 PM »
Excellent app, however I seem to have an isseu with it finding episodes in a series.
For example I have Dexter Season 1, in a folder below that I have all the episodes in Season 1 called Dexter S01E01 etc, the app finds the main season but every episode says something about missing information - Is there a way to get episode info as well as the main season? I must be doing something wrong somewhere.
Offline Zakkie
  • Moder8or
« Reply #7 on: March 09, 2013, 09:33:02 PM »
Thank you Robinc!
Offline Zakkie
  • Moder8or
« Reply #8 on: March 09, 2013, 09:41:00 PM »
starwarsclark,
Send me an image or directory listing of Dexter
Am sure it's most likely the naming or structure problem.
Should be:
Dexter         (This is the series folder)
    Season 1        (This is the season folder)
       Dexter S01E01
       Dexter S01E02
       Dexter S01E03...etc
Offline Whooper
« Reply #9 on: March 09, 2013, 10:51:52 PM »
Nice tool. Many Tks. :)
Sorry my English is not the best, I'm using the Google translator.
« Reply #10 on: March 10, 2013, 07:59:55 AM »
Great tool. For all those people that have been posting about series support on Mede8er - please try this tool. It makes things a lot easier and gives a nice series wall.
« Reply #11 on: March 10, 2013, 01:24:42 PM »
starwarsclark,
Should be:
       Dexter S01E01
       Dexter S01E02
       Dexter S01E03...etc
Thanks for offering to help - (sorry for the delay in replying, been laying a new bathroom floor!)
OK, my structure is:
TV Series
Dexter
Season 01
Dexter S01E01
When I run TV Rename it finds the season OK, I get details about the main series but not each episode (even though each episode details appear under My Shows tab), under the Scan tab I get, for example this:
Missing (12 items)
Show         Season          Episode             Date                     Folder        Episode/Filename
Dexter          1                          1             02/10/2006        \\X3d\hdd\TV Series\Dexter\ Season 01      Dexter-S01E01 - Dexter
The same problem happens with all 3 seasons of Deadwood, must be something I am doing wrong somewhere obvious.
Thanks.
Offline Zakkie
  • Moder8or
« Reply #12 on: March 10, 2013, 02:20:47 PM »
starwarsclark,,
Is it possible for you to do a print screen of your folder layout and post it here or email it to me?
Tx
Zakkie
« Reply #13 on: March 10, 2013, 02:33:13 PM »
Hi, is this what you need?
Structure:
HDD in Mede8er
X3D...
HDD1...
TV Series folder
Dexter folder
Season 1 folder
Dexter S01E01 folder etc, each episode is in it's own folder and there are 12 episodes in season 1
In the episode folder there is;
About jpg
Dexter-S01E01-Dexter (this is the actual episode MKV)
Dexter-S01E01-Dexter (XML)
Fanart jpg
Folder jpg
For Episode 2 folder you have as per above but only the episode MKV and folder jpg are in there, nothing else is written into this folder
Offline Zakkie
  • Moder8or
« Reply #14 on: March 10, 2013, 02:46:19 PM »
K...now I get you.
Don't create a folder for each episode.
Just throw all your video files into Season 1 folder.....do this for each Season as required.
    Season 1        (This is the season 1 folder, and your season 1 video files must be all in here)
       Dexter S01E01
       Dexter S01E02
       Dexter S01E03...etc
    Season 2        (This is the season 2 folder, and your season 2 video files must be all in here)
       Dexter S02E01
       Dexter S02E02
       Dexter S02E03...etc
and so on......
