Author Topic: Music on internal HDD not accesable  (Read 1829 times)
Offline Mike42
« on: February 21, 2013, 09:53:50 AM »
Today startet (again) with tagging of my music collection. (or still)
But i couldn't see the content of my music on  the HDD via my pc. folders where there but empty.(also tag scanner had no acces)
FOUND THE ISSUE: MED shuts down or crashes when you switch on med and then select an other channel on your tv.
because when i switch to the med channel the tv finds no signal from the med. --> crash
mike42
« Last Edit: February 21, 2013, 10:13:31 AM by Mike42 »
Mede8er : MED1000X3D
Network: Wired CAT5
AV receiver: Onkyo TX-NR414
additional equipment:
Re: Music on internal HDD not accesable
« Reply #1 on: February 21, 2013, 10:18:00 AM »
Do you have CEC on? Your TV could be green mad and shutting down sources you change from.
« Last Edit: February 21, 2013, 10:28:59 AM by jer1956 »
Offline Mike42
« Reply #2 on: February 21, 2013, 10:36:31 AM »
Do you have CEC on?
yes i'm sure it's samba and my cec setting is off,
currently testing by :
CEC on and one touch stanby on off --> still an problem
leaving the tv on the same channel --> again problem.
« Last Edit: February 21, 2013, 11:11:57 AM by Mike42 »
Network: Wired CAT5
« Reply #3 on: February 21, 2013, 10:51:56 AM »
What  events are set up for 5 mins...screensaver, drive shutdown?
You could peform  an  experiment. Power off tv and x3d (I do mean no power..not standby) Remove the HDMI cable and pwer up.  The samba server should be available, and the TV has no influence without HDMI.
« Last Edit: February 21, 2013, 11:05:33 AM by jer1956 »
Offline Mike42
« Reply #4 on: February 21, 2013, 11:12:09 AM »
yep did some more tests, MED crashes when screen saver kicked in, was using X3_man on the moon from Glynrs2. loaded my own skin (X3_Blue_moon) no more problems !!!  ;D
mike42  8)
Network: Wired CAT5
