Author Topic: Login network  (Read 1333 times)
Offline fiscalo
Login network
« on: February 21, 2013, 07:45:55 AM »
I have to put in a user name and pass word. Is this normal?
In Win7 I cannot access the network eather.
Re: Login network
« Reply #1 on: February 21, 2013, 09:15:34 AM »
It's normal  for  a Network with problems. A connection can  fail for many reasons.and the error gets passed up the stack until the password entry code posts it's error message.
The  most common cuase is a local DNS failure cause by using the wrong DNS server for your network.  127.0.0.1 may not work well on some networks.  See Avoid Tip 1.0.5.  http://www.mede8erforum.com/index.php/topic,9743.msg61258.html#msg61258
