Author Topic: issues connecting to Win XP pc via network  (Read 2095 times)
Offline Poemapaul
« on: January 27, 2013, 05:58:14 PM »
Hi all,
i'm afraid i l will need some help with the following. Just bought a 600X3D (no harddisk), with the following settings:
Firmware upgraded to 1.0.5. (11 jan 2013)
Network layout is as follows:
Modem connected to internet.
Behind the modem i have a netgear switch, which has: 1) TP-Link Access point, 2) Win XP PC (SP3) 3) MED600X3D
I have shared folder D:\Video's
When i try to access this folder via network, i can see the workgroup, and my PC.
However: wenever I try to go further, i'm prompted for a username/password.
Nothing works, i just get "logon fail".
I'm guessing the problem is in my PC, so i've tried the following:
- simple file sharing switched off
- Sharing permissions configured to Everyone (all access) and Guest (all access)
- Security set to full control for both Everyone and Guest
- Opened port 21 in McAfee firewall
- installed TCP/IPV6 protocol
- tried installing LLTD responder (which was not necessary because i have SP3)
Still no change in my problem. Any ideas what might help?
Thanks!
Offline BKSL
Re: issues connecting to Win XP pc via network
« Reply #1 on: January 29, 2013, 02:38:10 PM »
Try "simple file sharing" switch to on. Switch winXP firewall complete to off.
I use winXP SP3 with MED1000X3D and it works OK. MED has activated SAMBA process.
I can delete files in both directions. MED can remotely delete files on winXP-PC and winXP-PC can remotely delete files on MED.
MED1000X3D + 3TB HDD
Pioneer PDP-LX5090 ( FullHD, 24p, 1:1 pixel mapping )
2x JAMO S 718 (3-way bassreflex floorstanding speakers )
TP-LINK N600 Wireless Dual Band Gigabit Router
Offline Poemapaul
« Reply #2 on: January 29, 2013, 02:59:49 PM »
OMFG, just turning off firewall was the key  :-[ lol
Is there a safer way by any chance?
Only thing is that accessing my videos folder takes a long time. Any ideas on this?
Offline BKSL
« Reply #3 on: January 29, 2013, 03:10:07 PM »
If your devices are in home network no firewall in PC is needed, only in router - crossing WAN to LAN.
"accessing my videos folder takes a long time" it can be problem with slow PC or too many files in "videos" folder.
Offline Poemapaul
« Reply #4 on: January 29, 2013, 03:13:21 PM »
Ok, thanks a lot.
I think it might be a combination of those.
Thanks again!
