Author Topic: Network speed  (Read 7151 times)
Offline parper
Re: Network speed
« Reply #15 on: February 10, 2013, 12:11:03 PM »
it is.
Re: Network speed
« Reply #16 on: February 10, 2013, 01:47:36 PM »
If you where building from  scratch..I would tell you what we tell others. By all means go  for broke and connect it all up and hope if works. When it  doesn't work you have to  break it down and build it up slowly, even if you have to do it in one room and not as you want it finally.  Even  swapping med's requires this approach if they  are not using the same chips. So  coming form sigma is not going to  be a "drop in replacement".
