Author Topic: Connection to server - Fine one boot up, the next no access  (Read 1638 times)
Offline Gazanimal
« on: January 22, 2013, 10:19:11 PM »
Got my 600X connected to my network Netgear switch that then goes to another Netgear switch where my server & PC is.
Some times on boot up the Med8er finds the Shortcuts fine, other times it just doesn't see them & I have to either restart the server (which isn't good as I use it as for my TeamSpeak 3 server)  or reboot the switch.
Not sure why, but it's been fine for the last week, while I've been away and not using the main PC which also is connected to the same switch as the server, but as soon as the Missus wanted to watch a film tonight it lost connection.
Any ideas?
Offline couto
Re: Connection to server - Fine one boot up, the next no access
« Reply #1 on: January 22, 2013, 11:19:14 PM »
the switches are wireless or wired?
1- try to remove one of the middle switches from the equation for test purposes and test.
2- swap switch 1 with number 2
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
