Author Topic: Yadis2mede8er  (Read 457194 times)
nenito2k
  • Guest
Re: Yadis2mede8er
« Reply #465 on: June 09, 2014, 10:35:54 AM »
dunno where, but is is available on other sites...UK, FRANCE etc...look around !
On a side note, using the internal scraper all my series went fine! However HOW on earth can i edit them ???
for movie i did it, but series cant seem to work ! The edit button does not allow to change fanart or anything else !
Offline privat75
Re: Yadis2mede8er
« Reply #466 on: June 14, 2014, 02:04:18 PM »
Someone have another Downloadlink, cant use both. ??? ???
Offline inikad
Re: Yadis2mede8er
« Reply #467 on: June 14, 2014, 11:32:46 PM »
Here is a link for the latest build:
Yadis2Mede8er (Build 1.1)
« Last Edit: October 10, 2016, 10:38:19 PM by inikad »
Offline privat75
Re: Yadis2mede8er
« Reply #468 on: June 15, 2014, 10:22:30 AM »
Thank you.  :)
Offline iJazz
Re: Yadis2mede8er
« Reply #469 on: July 13, 2014, 06:50:25 PM »
I have encountered a problem with Yadis2mede8er where only the files for the movies in my list with a round rating number (e.g. 6, 7, 8 etc) are copied over to my movies folder. All movies with a rating number including decimals seem to give the following error:
" error processing <rating>, value 7,7 doesn't match you local numbering settings : nl-NL, movie skipped "
How can I get this to work, without having to manually copy all the files over to my movies folder?
Offline sajidassad
Re: Yadis2mede8er
« Reply #470 on: August 12, 2014, 03:58:30 PM »
when I download 1.1 version the y2m file gets caught by my antivirus and gets deleted...any fix
Offline auburnu008
Re: Yadis2mede8er
« Reply #471 on: August 25, 2014, 04:30:34 AM »
Can anyone please help me? I have tried everything and am having issues with the 600x3d finding the correct path to my files. Here is the thread with detailed information on the issues.
http://www.mede8erforum.com/index.php/topic,14952.0.html
Offline wilfried97
Re: Yadis2mede8er
« Reply #472 on: October 21, 2014, 04:36:49 PM »
Hi! I have got a problem with yadis2mede8er . It is written "out of memory" ! i don't understand! can you help me please?
Offline JohnWB
Re: Yadis2mede8er
« Reply #473 on: January 12, 2015, 07:18:06 PM »
I am getting the same message, details below. Any ideas what the problem is please.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.OutOfMemoryException: Out of memory.
   at System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement)
   at yaDIS2mede8er.Movie.ResizePicture(String srcFile, String dstFile, Int32 width, Int32 height, Int64 quality)
   at yaDIS2mede8er.Movie.CopyFolderJpgFile(String srcFile, String dstFile)
   at yaDIS2mede8er.Movie.Process(String movie)
   at yaDIS2mede8er.Form1.Mede8erize()
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
yaDIS2mede8er
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///D:/Johns%20Documents%20and%20Settings/My%20Downloads/Yadis2mede8er_1_1_280513(2)/yaDIS2mede8er.exe
    Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
    Win32 Version: 4.0.30319.34238 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    Win32 Version: 4.0.30319.34234 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Sony KDL-50W829B, Marantz SR7010, Panasonic BD35, Logitech Elite, Virgin V6, Mission 752, Mission 75C, Wharfedall 9.0, BK XLS200 Mk 2, iPhone 6S, Synology 214Play, Wetek Play2, Mede8er MED600X3D, Amazon Fire Stick, Apple TV2, NowTV, Airport Extremes
Offline Georgia35
Re: Yadis2mede8er
« Reply #474 on: April 16, 2015, 10:27:19 PM »
Bonjour,
Je me permet de vous écrire en français et de vous demander de l'aide ici car on m'a dit que l'auteur du logiciel Yadis2mede8er se trouvait ici et est français parait-il.
J'ai un problème que je n'arrive pas à résoudre tout seul.
Lorsque j'utilise Yadis2mede8er, au moment ou je clique sur Mede8erize, il scanne que la moitié de ma liste de films, se stoppe et me laisse un message d'erreur :
VOICI L’INTÉGRALITÉ DU MESSAGE D'ERREUR :
Mémoire insuffisante
Une exception non gérée s'est produite dans votre application.............., l'application va s'arrêter immédiatement.
Consultez la fin de ce message pour plus de détails sur l'appel du débogage
juste-à-temps (JIT) à la place de cette boîte de dialogue.
************** Texte de l'exception **************
System.OutOfMemoryException: Mémoire insuffisante.
à System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement)
à yaDIS2mede8er.Movie.ResizePicture(String srcFile, String dstFile, Int32 width, Int32 height, Int64 quality)
à yaDIS2mede8er.Movie.CreateMiniature(String srcFile, String dstFile)
à yaDIS2mede8er.Movie.Process(String movie)
à yaDIS2mede8er.Form1.Mede8erize()
à System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.ButtonBase.WndProc(Message& m)
à System.Windows.Forms.Button.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assemblys chargés **************
mscorlib
Version de l'assembly : 4.0.0.0
Version Win32 : 4.0.30319.34209 built by: FX452RTMGDR
CodeBase : file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
yaDIS2mede8er
Version de l'assembly : 1.0.0.0
Version Win32 : 1.0.0.0
CodeBase : file:///D:/YADIS2MEDE8ER/Yadis2mede8er_1_1_280513/yaDIS2mede8er.exe
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
Version Win32 : 4.0.30319.34239 built by: FX452RTMGDR
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Version Win32 : 4.0.30319.34230 built by: FX452RTMGDR
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Drawing.resources
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.resources/v4.0_4.0.0.0_fr_b03f5f7f11d50a3a/System.Drawing.resources.dll
System.Windows.Forms.resources
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll
mscorlib.resources
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/mscorlib.resources.dll
************** Débogage JIT **************
Pour activer le débogage juste-à-temps (JIT), le fichier de configuration pour cette
application ou cet ordinateur (machine.config) doit avoir la valeur
jitDebugging définie dans la section system.windows.forms.
L'application doit également être compilée avec le débogage
activé.
Par exemple :
<configuration>
</configuration>
Lorsque le débogage juste-à-temps est activé, les exceptions non gérées
seront envoyées au débogueur JIT inscrit sur l'ordinateur
plutôt que d'être gérées par cette boîte de dialogue.
Que se passe t-il ?
Comment puis faire pour résoudre ce problème ?  ???
Merci, cordialement  ::)
Offline plouie10
Yadis2mede8er
« Reply #475 on: September 29, 2015, 04:08:13 PM »
Perhaps someone could tell me how this works. Currently have DUNE HD products using Yadis. Works great. then purchased a 600x3D. So used Yadis2mede8er. Seemed to work. Now when I open up the movie folder all the fanart shows up. When I used to click on the fanart of the movie in Dune it would then show the synopsis, then click once more and it will play the movie. In Mede8er if I click the fanart it goes and shows the file, then if I click on the file it plays. It doesn't show the synopsis unless I click the info button the the Mede8er remote. Is this the way it works?
Offline osw2610
Re: Yadis2mede8er
« Reply #476 on: January 06, 2016, 03:31:44 PM »
Hello.
First I have to be sorry for my english.
I scraped all my films with yadis. (super tutorial, thx.)
But there is one thing, I would like to change, but I dont know how.
Is it possible to make a "Blu Ray frame" around the folder.jpg ?
I hope you understand, what I mean?!
I would have the same folder.jpg like the cover of the about.jpg (which I allways made with this frame)
I hope, that someone can help me.
Regards, osw2610
Offline tonyluelmo
Re: Yadis2mede8er
« Reply #477 on: April 27, 2017, 09:33:36 AM »
Please help me and i'm sorry for write in french... So thanks
« Last Edit: April 27, 2017, 10:00:22 AM by tonyluelmo »
Offline momo2013
Re: Yadis2mede8er
« Reply #478 on: March 01, 2021, 08:29:42 PM »
For all people who have memory usage problems during scan of films.
Just watch the title of the film processed during the message and then just move it from your collection, you can always process it manually later or even delete it to be sure.
